XenForo How To Create Custom User Group Icons For XenForo
hifitechindia
hifitechindia
Administrator
Staff member
Downloaded
0 bytes
Uploaded
0 bytes
Ratio
Seedbonus
0
Upload Count
1 (0)
Credits
0
Offline
Hello everyone,
Since many users have reached out to try and receive explanations of various customizations around our community, I've deciced to write up a quick tutorial on how to enable custom user group icons in front of your group names.
This modification is pretty simple since there is no need for custom-template syntax (JS/jQuery) to achieve these results.
1. Finding Your Group IDs​
The first thing you need to do is check which IDs are specific for your user groups. You can do this by viewing the user group from your AdminCP.
The group ID will be displayed within the address bar when you click to edit the user group, like so:
My Administration group ID is equal to 3
Once you've found your user group IDs, write them down and continue on with the tutorial.
2. Creating & Enabling Custom CSS​
Each group ID will need specific styling in order to achieve placing the custom icon in front of the username.
If you have multiple groups, the icon of the group with the highest priority will be displayed
CSS:
/* ====== CUSTOM USERNAME ICONS ====== */
.username--style1::before { /* Unregistered icon */
    background: url(https://google.com/ThisIsAnExampleImage.png);
    width: 20px;
    height: 20px;
    content: "";
    background-position: center !important;
    background-size: cover !important;
    background-repeat: no-repeat !important;
    display: inline-block;
    margin-right: 1px;
.username--style2::before { /* Member icon */
    background: url();
    width: 20px;
    height: 20px;
    content: "";
    margin-right: 1px;
.username--style3::before { /* Administration icon */
    background: url();
    width: 20px;
    height: 20px;
    content: "";
    margin-right: 1px;
/* ====== END CUSTOM USERNAME ICONS ====== */
The image/gif content you'd like to show should be inputted as a URL within the background: url(); key for each styling property.
Example: background: url(
Similar threads
hifitechindia
XF version 2.0 2.1 2.2 When you install XenForo on Hosting or VPS, your forum always displays the copyright line in the footer. This will be more annoying when this copyright line is added with information from the addons developer when you accidentally install an additional one. certain...
Replies
2
Views
114
Dcerkew
D
hifitechindia
  • Locked
xfrm_updates find search replace Chang Logs
Replies
0
Views
99
hifitechindia
hifitechindia
hifitechindia
This happens after i've installed addon from archive in admin panel.... Anything to resolve this? error_log file located in forum's root is empty. An error occurred while the page was being generated. Please try again later. FIX: GO TO FILEMANAGER src/config.php add code...
Replies
0
Views
254
hifitechindia
hifitechindia
mani5grockers
Confirmed that src/config.php contains: $config['maxImageResizePixelCount'] = 60000000; Options > Resource Manager > Maximum resource file size (KB) My server allows 500MB and this is confirmed on the admin dashboard and also on the attachment size page.
Replies
0
Views
379
mani5grockers
mani5grockers
hifitechindia
TYPE 1 Please try placing this code into your extra.less template /* Remove footer copyright information */ .p-footer-copyright { display: none; } # = ID element. = Class element You can use your browser element inspector to figure out what the name of the div/ID/span of the element containing...
Replies
0
Views
342
hifitechindia
hifitechindia
hifitechindia
XenForo has many addons, and the official are XFRM and XFMG We can change the name "Resource" to "Download" in Phrase, but the URL still "yourdomain.com/resources" Go to "Setup > Route Filters" Find route : resources/ Replace with : download/ Now, you have, "yourdomain.com/download" You can...
Replies
0
Views
262
hifitechindia
hifitechindia
hifitechindia
Sometimes, we want different color for each category forum. So here simple css which you want to try. Add to extra.less in your template. /* Coloring Category and Node */ .block.block--category.block--categoryXX .block-header { background: -webkit-linear-gradient(335deg, #28356c 44%, #074946...
Replies
0
Views
292
hifitechindia
hifitechindia
hifitechindia
How to limit the size of Google AdSense ads This code is directly from Google support. Please note that this will not work for AutoAds. How to modify your responsive ad code - Google AdSense Help If you find that our responsive ad code doesn't do everything you need, you may modify your ad code...
Replies
0
Views
273
hifitechindia
hifitechindia
hifitechindia
If you want to provide an extra layer of protection to admin.php, the /install directory, and test & development installations, you can do so with .htaccess authentication. Protecting admin.php To protect admin.php, edit the .htaccess file which is in your forum root directory (e.g...
Replies
0
Views
238
hifitechindia
hifitechindia
Users who are viewing this thread
